hi,
as per the explaination on the net, i did exactly the same. the steps are as follows.
1. Copy the file c:\windows\system32\wpa.dbl to a floppy.
2. Reinstall Windows XP.
3. Boot to a DOS disk if you are using FAT, or to the Recovery Console if using NTFS.
4. Copy the file from the first step above back to c:\windows\system32.
well, reg recovery console, i did as i got instruction on net.
did put the CD in startup and when the CD boots, after some time it displays a message having 3 options and recovery console being one among them. on selecting it, it goes to DOS mode.
here come the issue.
i made a back up of wpa.dbl in floppy before reinstallation (14 KB) size. here, i copied the file which was now 5 KB only. well, when viewed, it showes the 14 KB size. then exit was done which reboots the computer.
now when i see it by explorer, the file size returns back to 5 KB though i had changed it. i did this step for 3-4 times but everytime the same thing happens.
as per my system, its original PCS brand make with a XP pro sticker on the cabinet. well, upon recovery i need to enter the key again in middle of installation which i gave the same as in sticker.
so, what is the issue??? why is wpa.dbl being re changed to its orignal size again and again. pls suggest as i am really annoyed. being a licenced customer, i feel that this is not nice.
lastly, i did the same with safe mode also, but this too in vain. al the time, it comes back to its original size.
any idea pls, Gurus...
ken
ken
