Really Strange Monitor problem
saROMan
saROMan
QA Juggler
Contined ................
Green Color
Original Image :
http://www.bombiadesign.com/downloads/desktops/blocks_green_1024x768.jpg
Yellow Color
Original Image :
http://www.pixeldiva.co.uk/photo/gallery/yellow-flower-ie.jpgn3.gif
also when i go in Graphic controller properties i cant change the BMP ..nor can i restore to default as they are grayed out ...is it the Real Problem ???
My Monitor is IBM E54 Black 15" CRT Monitor ( 633147N )
Motherboard/Chipset : 845G Family
Display Adapter :Intel 82845G/GL/GE/PE/GV Graphic Controller
I have Uninstalled AGP / Display Drivers ...searched and Updated Monitor
Drivers......Checked If my Monitor Pin/Connector are damaged ....but no use....I have done every thing in my power to Resolve the
Problem...but Failed
may be any 1 here can help me....
Note : All images are clickable Thumbnails...
vandit
the pics u have posted seem quite fine to me......no probs....what wierd problem are u trying to tell abt???
the.kaushik
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
yap me too... but if still u hav problem reinstall ur windows and still if u hav then report..
QwertyManiac
Commander in Chief
Arre lol its a monitor fault, VGA is fine and thats why screenshots are OK now. Check you monitor settings and make them to factory settings again. Also try degaussing. How old is it ?
djmykey
Let the music play.....
Monitor gaya re babu. The screenies r fine, really fine. Monitor mein shot hain. Try checking the cable for twists/knots if everything is fine then u gotta give the monitor 4 repair.
saROMan
saROMan
QA Juggler
damn after loking at repys..seems that there is fault in monitor only :( ..coz here i cant see any RED Color..nor YEllow ..every thing looks pale..also this PC is a bit new 1 ....IBM Netvista ....damn will have to call the Enggenier ...hay any 1 know whome to call for help in CHENNAI ???
