karthik_rcs
Hello friends,
I am using windows xp sp2. Long time ago i installed window blinds 4.4 version.
Before Installing wblinds ,
In the display properties window ->Appearance tab -> Effects was working fine.
After installing wblinds, the effects button wasnt working.
I suspect that wblinds overwritten any system components.
If you have this type of issue request you to revert back to me. please with the solution. The worst case is to reinstall or repair windows.
If there is anyother alternative please reply.
SUGGESTION/LESSON : NOT TO INSTALL ANY THEME RELATED COMPONENTS LIKE WBLINDS,TALISMAN...
Thanks in advance
Thanks in advance
