56561
Last night suddenly an explosion occured inside my pc and it turned off . i had LiteOn DVD writer . i understood that something occured inside it . when I turned it on the PC LEDs turned on but nothing loaded , i opened the optical drive...yes the dvd turned into 1000 s of fragments .
what should i do now? well I want to know do i need to change the optical drive or it can be curable?
and is my HDD, ram also affcted ?if only optical drive went out then others should work?????
can anyone tell me some good places where I can take my PC for a low cost cure? I stay in navi-mumbai area .
reply please........
