s18000rpm said:you dont have to heat the Heat Sink like that, just use the PC for 5-10 mins. which heats up the Paste, & now the Heat Sink can be removed easily.
__________
btw in my PC the CPU Fan/heatsink are Screwd onto the mobo, no clips no nothing.
