djsonicsid
hey , i have a Local Internet ( Dishnet ) at my home , my network is very small & most of my friends are not on the same LAN Connection , i stay on 3rd floor of my building , 1 of my friend who stays on 9th floor also has Internet ( Pace net ) which is totally on the other Network , on that Network (pace net) most of my friends are sharing the files with the help of DC++ Software thru LAN Connection , all of them are on same Network(pacenet), so they r using the LAN Connection for sharing the files & they r getin around 1-2MB/Sec
now i wanna ask u 1 thing
i have 2 LAN Cards
on 1st LAN Card my Dishnet Local Internet in there
on 2nd LAN Card nothing is there .
so if i bought a T- Connector (which can split 1 wire in to 2 i.e 1:2 Lan splitter , Cross over cable & RJ45 Connector , will i b able to connect to Pacenet Network with the help of my friend's LAN
If i join a wire From my friends INTERNET wire(pacenet Network) to my PC & put it on my 2nd Lan Card ,will it work properly with the ip settings
Plzz plzz Help me . guide me in this problem without the help of any HUB OR SWITCH , give me a easest & simplest solution
i have 2 LAN Cards
