Need help in Building a PC
Discussion in 'Hardware Q&A' started by troubleshooter, Apr 16, 2006.
Thread Status:
  1. troubleshooter
    troubleshooter New Member
    Nov 29, 2003
    90
    0
    0
    I would like to build my own rig. My budget is between 30k - 35k. Main use would be games with decent picture quality, office applications, surfing in the order of priority. Please suggest the configuration for the same.
  2. samrulez
    samrulez New Member
    Apr 16, 2006
    1,334
    4
    0
    You can get a good pc for 30--35 k
    It should be
    CPU amd Athlon 64 3200+ (939) -------------------7500
    Mother board Asus A8n vm csm----------------------6500
    Ram 512MB 400 mhz Hynix---------------------------3500
    HDD 120 Gig SATA Segate----------------------------2650
    Monitor Samsung DF793 (17 inch)--------------------6500
    Key board logitech-------------------------------------300
    Mouse logotech-----------------------------------------300
    Cabinet Any --------------------------------------------500
    SMPS VIP 350 watt-------------------------------------2000
    Optic drive lite-on DvD writter------------------------2750
    speakers Creative Inspire 2.1 -----------------------2400
    Total============================= 34,900
    Graphics Card nVidia 6600 GT --------------------12000
  3. myhotdog
    myhotdog New Member
    Dec 15, 2005
    158
    0
    0
    patila
    I have one doubt ! Is 350Watt of power supply good for him. well rest r good
  4. Kniwor
    Kniwor Learner
    Sep 14, 2005
    1,949
    6
    0
    Chicago
    since u are getting a new system get a colorsit 400W or more PSU.....
    350 might do but why take chances... at some point of time u might want to use many USB devices... and PSU might yield
  5. jay4u
    jay4u New Member
    Mar 21, 2005
    319
    1
    0
    Mumbai
    the prices u quote are far above average in some case like the mobo and gfx card prices.... please check at deltapage.com or mahavir.co.in and then go for the deal....
  6. samrulez
    samrulez New Member
    Apr 16, 2006
    1,334
    4
    0
    OOps yes go for a 400 watt SMPS make sure it is good one maybe ANTEC or VIP
  7. maheswar2006
    maheswar2006 New Member
    Apr 12, 2006
    30
    0
    0
    Planet Earth Mumbai, where else?
    If u r going to buy a separate graphics card, then go for the ASUS A8NE nfore4 ultra motherboard.
    otherwise its ok
  8. kjuvale
    kjuvale Pharmaguru
    May 2, 2004
    380
    2
    0
    Pune
    For monitor instead of DF793 go for 798MB plus it costs 6500 and its latest model
  9. Ethan_Hunt
    Ethan_Hunt New Member
    Jun 26, 2004
    5,219
    10
    0
    Bombay, India
    The Config that Samrulez gave resembles the exact same Config recommended by Agent 001 in Digit.:D
    As the Hynix Models of 512MB DDR ram is never that freaking costly.Nor is the Pricing is the Motheboard and Processor.
    Now coming Back to the main Topic,The config must go somewhat as follows:
    AMD Athlon 64 3000+ (S939)
    Asus A8N VM
    Transcend 512*2 MB DDR RAM @400Mhz
    160GB Segate Barracuda SATA HDD @7200Rpm
    Samsung/Viewsonic 17"Monitor (Flat)
    I-Ball Grabit Cabinet with 400Watts SMPS (OR Opt for a Powersafe 400Watts SMPS)
    Creative SBS 370 2.1 Speakers
    Microsoft Mouse and Keyboard
    Lite-On/Sony DRU810 DVD Writer.
  10. myhotdog
    myhotdog New Member
    Dec 15, 2005
    158
    0
    0
    patila
    I think 160GB of HDD is useless. My suggestion go with 80GB and why r u want 17" monitor it's also waste of money coz you r building PC not a TV rest above r good
  11. OP
    troubleshooter
    Nov 29, 2003
    90
    0
    0
    Thanx everyone for replying. I wanted to know whether the mobo mentioned in your posts (Asus A8N VM ) has on board graphics and sound card. Whether it will suffice for playing games at decent resolutions. Instead of Samsung 17" Flat can i opt for a 15" LCD of Benq or Acer.
  12. drvarunmehta
    drvarunmehta New Member
    Nov 3, 2004
    1,533
    17
    0
    Yes the Asus A8N VM has onboard graphics and sound. It's good enough to play the latest games at low resolutions and old games at higher resolutions.
    Don't take a 15" monitor under any condition. It's too d@mn small. Take a 17" CRT or a 17" TFT if you can afford it.
Thread Status:
Share This Page
