Need for head lights and crowd
Discussion in 'QnA (read only)' started by vijaythefool, Sep 13, 2004.
Thread Status:
  1. vijaythefool
    vijaythefool New Member
    Aug 18, 2004
    339
    0
    0
    ..:::In Beautiful Hearts:::....
    How can i enable crowd and heads light on nfs underground version 1
    iam using a p4 pc with 512MB ram and intel genuine mother board and no other graphics card ! what could get me the crowd and head light ?
    Vijay
  2. Nemesis
    Nemesis New Member
    Jan 26, 2004
    1,634
    0
    0
    New York
    there is the option somewhere in the options-i think in the graphics/video options. not sure though. i havent changed settings in a while....
  3. gxsaurav
    gxsaurav Guest
    that won't wotk, crowd & headlite requirs Pixel Shader 1.4 support atleast
  4. OP
    vijaythefool
    Aug 18, 2004
    339
    0
    0
    Need light and crowd buddies i need them ! :(
    what is pixel shader support 1.4 is that a any software that i can download ?
    or should i move for a g-force graphic card or some other graphic card ?
    Vijay
  5. OP
    vijaythefool
    Aug 18, 2004
    339
    0
    0
    headlights needed
    now can u tell me what is a pixel shader hope it is a software and if a hardware how much it costs :(
    vijay
  6. gxsaurav
    gxsaurav Guest
    Re: headlights needed
    Pixel Shadr is a hardware only feaure, U will need a GeForceFX card or Radeon 9seris, it will cost U atleast Rs 3500
  7. allajunaki
    allajunaki New Member
    Jul 20, 2004
    143
    0
    0
    Somewhere In my room....
    Dude,gxgaurav! ... What?!?!?!
    for playing NFS UG (need For Speed UnderGround) you need @least pixel shader 1.1 and NOT 1.4,
    that means crowds and headlight and motion blur will be activated only if you have GeForce3 Ti or GeForce4 Ti. (GeForce 4 MX dont have any shaders Be careful!!) or GeForce FX, and any ATI radeon 9xxxx series except ATI Radeon 9200 (I think..not too sure on Radeon Series)
  8. theraven
    theraven Active Member
    May 5, 2004
    2,912
    0
    36
    off to "never ever" land
    whats ur point ??
    basically he needs a new card and thats what gxsaurav advised him
    what diff does it make if its 1.1 or 1.4 ?
    u could have just politely made a correction ...
    relax a bit man .. we are all here to help/learn and make mistakes ;)
  9. Nemesis
    Nemesis New Member
    Jan 26, 2004
    1,634
    0
    0
    New York
    saurav, i run nfs ug with all eye candy turned on my geforce 3 ti 500 card.....
    and the minimum graphics card requirement is a geforce 2 or greater or a radeon 7500 or greater...
  10. 144
    144 New Member
    Sep 13, 2004
    178
    2
    0
    classified
    You will need Pixel Shader 1.1 atleast.
    For current Generation Games you need GeForce FX. entry level would be FX 5200. MX cards don't have the PS 1.1 feature.
Thread Status:
Share This Page
