techking_dinesh
Digit Squad Member
hello
i hav a hp desktop using since 2 yrs
asterope motherboard
nvidia geforce 6200se
1 gb ddr2 ram
my pc is not starting
i called the hp guyz
they replaced motherboard still same prob
they replaced ram still same prob
they added new gfx card still same prob
they replaced psu still same prob
but all 4 parts works well on in their test lab
all d drivers r up to date
wat can the problem be ??
the hp guyz bought a second hand old 6200se card and pc started wroking
nowadays diwali cleaning is going on
so i just unplugged whole system
cleaned my table
and plugged them back
and now the pc does not sttart again
but if i remove the gfx card it starts
it means i m facing the same prob
but wat is the permanent solution to it ??
my pc is under warranty
plz help as i hav very confidential data in my pc
thanks
w8ing for a quick and a useful solution
1 gb ddr2 ram
cleaned my table
thanks
