monitor led blinks,bt not working.pls help
Discussion in 'Hardware Q&A' started by mobileman, Oct 24, 2006.
Thread Status:
  1. mobileman
    mobileman New Member
    Mar 4, 2006
    256
    0
    0
    hi,
    i m using p4, sound,vga onboard.
    now wht i m facing s, whn i m switching the pc,cpu gets on.bt the monitor not getting switch on.its led gets flashed.whn trying to open the cd tray,no problm,its working,
    can any one,guide me to trouble shoot?
    waiting
    thanks in advance
  2. harpoon
    harpoon New Member
    Apr 27, 2004
    179
    0
    0
    Happened to me once.Check all the cables connection properly.
  3. Third Eye
    Third Eye gooby pls
    Apr 2, 2006
    4,293
    58
    48
    Not very far from you
    check your ram and cables.
  4. gaurav21r
    gaurav21r New Member
    Jun 21, 2006
    100
    0
    0
    High, High above, over that Blue Sky
    Check all cables.
    Maybe the refresh rate freq is set to some value not supported by your monitor???
  5. satyamy
    satyamy Alive Again...
    May 20, 2005
    1,665
    1
    0
    Mumbai
    ya right
    First check all ur cables than check ur RAM
    if wont work try to on u PC by removing some devices like LAN Card
  6. DukeNukem
    DukeNukem Come get Some
    Aug 28, 2005
    417
    2
    0
    Home Sweet Home
    have you done any changes in BIOS recently ????
    if Yes
    Then Reset The BIOS for Relief from your Current Misery.
    (To reset Bios Remove the Cell for About 5 minutes or if you Board has BIOS resetter Jumper DO IT)
  7. eureca_eureca
    eureca_eureca New Member
    Mar 18, 2005
    279
    0
    0
    Bath Tub
    Are u using d845 gvsr mobo ? i had the same problem , cd rom ejects and mobo lits up inside the cabinet , every thing appears working , except for blank monitor ...i got my mob repaired 5 times from diffrent places, at intel they said it had no problem , but never worked more than an hour each time .... hope this didnt happen to ur mobo too
    i was on the 3 rd year under warranty , i was not eevn given a new mobo :(
  8. Odoj
    Odoj New Member
    Oct 24, 2006
    11
    0
    0
    Faced this problem few years before.
    But the problem was with CMOS chip/battery. (cant recall exactly)
    CPU was unable to send the sync pulse to monitor.
    Do post, if you happen to solve the problem.
  9. s18000rpm
    s18000rpm ಠ_ಠ
    Mar 1, 2006
    5,608
    87
    48
    open your PC Cabinet & see if the Transistors (cylindrical things) around the Prcessor have SWOLLEN or have a Rusty LEAK overhead.
    if you see it, then get your mobo repaired.
    My friend suffered same problems.(his pc was 5-6 years old)
  10. abhijit_reddevil
    abhijit_reddevil Manchester United
    Jul 26, 2005
    1,447
    4
    38
    Kolkata, India
    Faced this problem 2-3 months back. Seems like the resistors/transistors/capacitors in the monitor PCB have gone put. Do not open the monitor yourself, get it repaired by a service technician. Maybe he will take Rs.100-Rs.200 as service charge.
  11. OP
    mobileman
    Mar 4, 2006
    256
    0
    0
    i removed all extra cards frm slots. still,same problm, tht,processr fan,smps every thing working,bt i cant get the normal buzzer whn booting. no output to monitor too.i ckcked with two monitors.bt same result.
    i m using Ashrok mother board .
    waiting to see replys
    thanks to all again
  12. royal
    royal New Member
    May 6, 2005
    834
    1
    0
    Kolkata
    Had the same problem sometime back...just took out the RAM module and inserted it again. That solved it :D
  13. OP
    mobileman
    Mar 4, 2006
    256
    0
    0
    ys.
    i already tried.i removed the ram frm the slot and put in the other one.
    still thr same problm
  14. royal
    royal New Member
    May 6, 2005
    834
    1
    0
    Kolkata
    try inserting in a different slot, if you haven't done that already...
    It could also have been Battery problem or as some other friends suggested, ur mobo have gone kaput :(
  15. DukeNukem
    Aug 28, 2005
    417
    2
    0
    Home Sweet Home
    they are called capacitors/condencers
  16. eminemence
    eminemence New Member
    Sep 27, 2004
    145
    0
    0
    Why not check the BIOS battery?
    --eminemence.
  17. s18000rpm
    s18000rpm ಠ_ಠ
    Mar 1, 2006
    5,608
    87
    48
    thanks for correcting me. :)
    @mobileman, did you check the Capacitors/Condencers???????, which are around the Processor
Thread Status:
Share This Page
