LAN Problem
amit2005
hi ....I'm using dataone bb with mt841 modem...me n my fren r able to share the net connection..but we r not able to share files b/w ourselves......i'v tired everything...in work group computers ..on my pC only my PC is displayed ..while on his pc his is shared folder r displayed..but we r not able see each other pc...we turned off firewalls..n other things ..plz guide
thnx
dOm1naTOr
try turning on remote desktop.
And have u enabled guest network user?
And also try running network setup wizard nd set same workgroup for both
ravi_9793
TechTin.com
1) Turn off firewall all firewall
2) run "Network setup wizard " on all computers. Select proper configuration while running this.
dOm1naTOr
Have anyone got peglinks worked? its some kinda fault finder in cables, but it dun work or i dun know how to get it worked.
