Internal TV Tuner Problem
Dipen01
Hey.
I hav one doubt ant TV Tuner Card.... Well my rig is PIII 1GHz 64 MB SD RAM.. ...
Will i be able to use it without any glitches on my PC...and yeah TV Tuner is Internal... and i even wanna record with its help...
Are there any other specifications for internal TV Tuner Card....??
So will it be OK..ya...bcoz...of RAM it will give me problems... :shock:
Regards,
Dipen
Techie_Geek
dude u need at least 256MB for smooth operations and with that config u will have trble with recording and time shifting. Go through old digits for TV Tuner configs
dIgItaL_BrAt
Your processor is decent enough for capturing,just consider increasing ur RAM to 128 or more for better performance during capturing.64 MB is enough for viewing.
ramprasad
Yes man,... RAM is not at all adequate....
I have P4 with 256 MB SDRAM and its really cool, both timeshifting and capturing...
Dipen01
Dipen01
Hey...
Thanx a lot for your advices...Atleast for now i can view it...!!
Will purchase another 128 or 256 later...
Regards,
Dipen
hsksattish
ya u can view with it. Only capturing is not possible.
Use original pvr software provided with it for best results-not winamp tv.
dIgItaL_BrAt
the Sourceforge drivers work for all cards based on the BT848/878 chipset and they offer much better picture quality and much lesser utilization of resources.
