How much power does my smps need?
gaurav_018
My smps current power rating is 235W
p3 933 {512mbRam}
I have two hard disks -seagate barracuda
DVDDrive, CD-writer
PCI modem
I recently installed a lan card and now while logged on the net my games crash. how many Watts should my smps be?
theraven
minimum nowadays ? ATLEAST a 300w .... within the next couple of months ATLEAST 350w ...
and for future chipsets etc. ... atleast 400+
G
gaurav_018
but Is my current power supply sufficiant? Please read my problem. while using both my lan card + cd drive while connected to the net my system crashes
akshayt
Take a 300watts if that doesn't satisfy you you may go for 350watts.
300watts=Rs.600-recommended
350=naer 1k-maximimum
400watts=1.2k(powersafwe)
theraven
ummm yeah akshayt is right
but yet ... i think u should get a 350w
its upto u anyways :D
you spoke abt ur system crashin ... and then ur askin abt ur smps
so what exactly seems to be the problem ?
i mean ... did it crash because ur smps was insufficient or what ?
i guess basically just tell us what u mean by "CRASH" exactly!!
akshayt
get yuor mobo checked.It can also be because the systerm got heated.Anyways 300watts ps isn't too expensive.
My config:
1.7ghz 478socket willamette
256mb sd 133 p4
40gb 7200
cd rw
cd rom
tnt2
mercury 300watts ps
theraven
hmm
well if there was a problem with his mobo then it wouldnt start i guess
anyways .... umm
do one thing ... do u have onboard graphics or a gfx card ?
if u have a card
try runnin it on ur onboard graphics ..
or borrow a friends card and check
and better still
borrow his smps and check ur system
ofcourse make sure HIS smps is 300w or above ..
let us know
G
gaurav_018
Yes I'm using a Geforce 4mX 64
I don't know anyone who would let me disconnect their SMPS.
My system is not crashing because it's getting over heated. my cabinet has two fans installed and the temp here is very low.
Let's refresh my problem:
If some one could tell me how to calculate the needed W then my problem would be solved.My detailed config
Pentium3 933
815 EPEA intel motherboard
256 * 2 Mb ram
Seagate ST32042H
SAMSUNG SV2042H
SAMSUNG CDRW 52 24 52
SAMSUNG DVD 8X
GERORCE 4 MX 64MB
CONEXANT SOFT56 DATA/FAX/VOICE PCI MODEM
D-LINK DFE-538TX 10/100 ADAPTOR
PS2 OPTICAL MOUSE FRONTECH
USING ONBOARD SOUND
STUDIOWORKS 775N (CONECTED TO A DIFFERENT POWERSUPLY)
theraven
@gaurav_018 like i said for that config u need atleast a 300w smps ...
@svenkat ... yeah .. which one did u get for that much ?
rock_ya_baby
gaurav_018 said:
thanks guys for all your help but i still would like to know how to calculate the W.
Hope this helps > *forums.tech-arena.com/showthread.php?t=4220
more specifically > *www.challenge-my.com/goopsulator/
