hi
I'd a Transcend V30 1 GB pen drive but whenever I tried to copy some data on it it says Cannot copy data because the path is too deep to copy...!!" (while copying the data) so i thought its a corrupted pen drive but i tried it on some other PCs n it worked ok but at a very slow speed.
So yesterday I purchased a New 2GB Pen Drive Sandisk Cruzer Micro U3. Now it is also showing me that it "Cannot copy data because the path is too deep to copy...!!" (while copying the data)
please tell me what should i do now? what can be the problem. i use my bluetooth dongle in the same port n its work fine n i also once formatted my pc thinking the problem may get over by this...
my pc config as follows - P4 1.7 GHz, 128 DDR Ram, Asus 845G motherboard
looking forward 4 your reply friends
thank you
Saurav
thank you
Saurav
