Help needed regarding display problems
Discussion in 'QnA (read only)' started by abhi_alpha_beta, Aug 7, 2006.
Thread Status:
  1. abhi_alpha_beta
    abhi_alpha_beta New Member
    Mar 1, 2006
    25
    0
    0
    hi everyone,i am unable to set 1024*768 resolution,even if i did,my screen would blank and i would a get notice saying operating frequency is higher,i have a 14 inch lg colourworks monitor,my mobo is mercury 845gv,512 mb ram ,p 4 1.8ghz,plz suggest a solution guys
  2. sakumar79
    sakumar79 Active Member
    Nov 28, 2004
    2,441
    9
    38
    Madurai
    Two major factors that affect resolution are monitor and graphics component (card or motherboard chipset). First, check they both support resoltuion (monitor is less likely as it is only 14"). If they are, first set the refresh rate to 60 Hz and then try...
    Arun
  3. ilugd
    ilugd Beware of the innocent
    Dec 25, 2005
    1,009
    3
    0
    it seems to be the problem because you are setting the monitor screen refresh rate to something higher to what the monitor supports. Right click on the desktop, select the screen saver tab, clikc on the advanced button, click on the monitor tab and try changing the refresh rate. Also try updating the display drivers.
  4. OP
    abhi_alpha_beta
    Mar 1, 2006
    25
    0
    0
    thank u for ur advice,i will try it
    thanks it worked
Thread Status:
Share This Page
