HELP NEEDED FOR MONITOR ISSUE
mandar5
Hi i am planning to buy 17inch monitor preferably crt of LG.I want to know whether flat or regular make any difference in output ,Is flat one really easy on eyes?Please reply soon. 8)
pimpom
Yes, flat CRTs are easier on the eye than non-flat ones. Buy a flat one if you can afford it. On a non-flat tube, images are distorted and lines look curved.
However, today's non-flat tubes are much less curved than those of several years ago. So if you're on a tight budget and are not doing any critical graphics work, non-flat displays are quite acceptable and the eye quickly adjusts itself to the slightly curved image.
