help: hw 2 install GCC in DSL ??
a_k_s_h_a_y
Dreaming
i want to install GCC in Damn Small Linux
i hv installed dsl thru virtual box !!
i could not install VLC player in DSL as it says no good or compatible compiler available
now how do i install GCC and then finally install any program that i want ??
i tried to google but i did not understand much
was there a sticky to install progs in linux ? where did it go ??
few months back i had same probs in ubuntu...but gave up instead !!
QwertyManiac
Commander in Chief
You can try to set up APT on DSL via:
*www.damnsmalllinux.org/dsl-n/f/viewtopic.php?t=98
And then apt-get install gcc from the MyDSL repositories which setting up the APT will give you access to.
