where do i start from......
ok
i have 4 partitions , C, D, E, F.......20 GB EACH OK.
the prob is i had win xp on D and win 98 on C
then 1 day i delelted 98 files from logging in in xp ...
then on startup it showed 2 options but only 1 worked thats win xp!!
there was a virus on D (xp) so i installed another XP (fresh ) on C again
...but that did not work after installation for some reason...so again i deleted the files after logging in from Dxp ....
so on boot up i had 3 option win xp win xp and win 98 ..but only 1 worked ..
by going in startup and recovery options i changed the text file and on boot up
now i have 2 options win xp(works)ndows default (doesnt work)...
ok
now the problem is i want to format C but i am unable to do so....
i log in from D ( xp ) and then in C(NTFS file sys) but it says windows was unable to complete the format ..
other way by going in CMD i try to format but no use ...
i think it s cauz of old system files left on C .(thought i cant see them)
so plzz suggest me how do i format C ....................
