HI,
my xp pro computer is not able to run help and support feature which activates upon pressing F1 on the desktop.
it shows that helpctr.exe is not available.
to make sure, i searched the same on another xp pro machine and then copied the same to my relative folder, i.e.
helpctr.exe to
C:\WINDOWS\PCHealth\HelpCtr\Binaries
C:\WINDOWS\ServicePackFiles\i386
HELPCTR.EXE-19FDF547.pf to
C:\WINDOWS\Prefetch
i have this 3 different file sized versions
HELPCTR.EXE-19FDF547.pf 15 KB
HELPCTR.EXE-19FDF547.pf 18 KB
HELPCTR.EXE-19FDF547.pf 53 KB
which one is the valid one
now when i run helpctr in binaries folder, it shows to start the service named Help and support service.
for this i went through services in adminitrative tools but didnt find any.
so where can i do the fixing stuff to solve this problem.
help me out...
aken
helpctr.exe to
C:\WINDOWS\Prefetch
help me out...
aken
