Having a problem..plzz help
smile
Hi.........Everyone :)
My friend send me a game in excel ... it was not opening , i thought its need a flash player to open so i installed ,but unfortunately it not opening . I have Vista installed and Microsoft Office 2003 but the same mail i forwarded to one of my my friend and their its working fine he too has vista and office 2003 installed:mad:..So what is the problem in my system?
Choto Cheeta
Rebooting
How can a game be in Excel ?? unless its some thing reading game or such :lol
: and why would an excel file need flash ??
the same mail i forwarded to one of my my friend and their its working fine he too has vista and office 2003 installed..So what is the problem in my system?
may be they have some update which your system is missing which is required to run the game, like SP3 or Office Compatibility Pack SP1 or such !!!
smile
smile
yes chota cheeta the game is in excel ...its called apple shooter ....i wil send u a mail if u like me to send ...can i have ur mail id :p:)
gopz
There are several games in Excel and a few in Word too. You can Google to find out more and update your knowledge, instead of laughing and mocking at someone who has come here to ask for help!
Amir.php
Flying Visitor
Right click game.exe
select the properties> compatibility tab> check "Run this program as admin"
now try run.
also can try to campatibility mode of xp(sp2)
quad_master
Tired of being sorry!
tell me 1 thing...when u open the game's excel file then MS Office pop-up a screen with 'enable/disable macro' option???:rolleyes:
dhanusaud
Lemme know if you have SWF player installed in your system or drag the game in Inter Explorer.
It sud work fine now.:)
quad_master
flw dis-
open that excel > tools > macro > security > set the security level to 'medium' > save the changes
reopen the excel file...'enable the macro' option...bingo!!
quad_master
@quad master : am not getting any pop up to enable macro when i open the excel
hmm...u sud get dat kinda pop-up:rolleyes:
btw if the file come in zip then u hav to extract it...then flw above steps
actually i have dat game...i faced da same problem...nd i sort it by this process
if evrything fails...dwnld again nd try afresh...:D
Amir.php
Flying Visitor
Last guess:
seems you are trying to run game directly from zip folder.
first extract into a folder, then run it.
