dvd writer read problem... help!
Arun the Gr8
frm few days ny sony dvd writer has become very slow in reading dvds. i just dont understand wht happened. when i play any song while copying from a dvd... the song runs very slow. also the data too gets copied at a very slow rate. can u guyz help?
Arun the Gr8
Arun the Gr8
Check whether dma is disabled...
how do i do it in win xp...
also.. burning process failed in 2 of my dvds... both sony while writing in 16x... though one dvd i burnt in 8x... and d data was verified successfully in it... wht do u think is d problm??
kayos
Boy Waiting To Be A Man!!
before using the vbs goto device manager and check for the primary and secondary rives in ATAPI controllers...
check in teh advanced setting if transfer mode in PIO or DMA..
if its PIO then make it DMA and restart ,..
check again .. it might have rechanged to PIO .. if it isnt then good otherwise run that vbs ..
if it still doesnt help then there is a tutorial in tutorial section ...
look for that ..
hope it helps !!!
slugger
Banned
if u have eliminated the UDMA issue and problem stil exits then check out this thread
http://thinkdigit.com/forum/showthread.php?t=80393
also 16x being the maximum ur writer can write at, better not to burn it at that speed. chances of failure increases manifold
8x is fine, tho 4x if feel is even better 4 ur writer [shud take around 15 mins 2 burn 4.5 GB]
