difference in internet speed in diff system
guhanath
Hi All,
I use hathway wifi connection(50mbps connection) in my home. I see a peculiar problem with respect to internet speed.
I have a desktop(win 10, updated to creators update), connected via wifi usb adapter(lexosys nano usb). I use flashget downloader/regular downloads in my browser.The desktop is near to router.
I have a laptop (vista) connected to the same router. The laptop is farther from router.
I noticed that my internet speed/download is very good(approx 3 mbps) when i use it from my laptop. However the net speed from my desktop is struggling around 250 kbps. I tried clearing cache/settings/ wifi reboot etc but the problem remains. I am noticing this issue only in the past 2 weeks (after creators update).
Can anyone suggest solutions/ techniques to resolve this issue? Should I try connect to LAN cable and verify/ clearn DNS cache etc?
Thanks
Guhan
patkim
Things to try
-As already suggested first check what speed you get on LAN cable. If it's good may be it's time to check on WiFi
-Try booting to a Live Linux distro say Linux Mint and check if it detects your WiFi adapter on Desktop, if yes and speed is good then it's most liklely Windows issue
-Try re-installing drivers for your WiFi adapter on Windows
-Do a system restore and check if any previous state was better.
-On your router try toggling WMM option (If exists) Try it with that option Enabled and other times Disabled and check if there's any difference
-I had a similar issue with my Sony Vaio laptop. The speed on WiFi was poor only on that laptop. Rest of the devices were good. I took a drastic step and invested my time in full and clean re-install of Windows 7 and WiFi drivers on my Vaio laptop and the problem was solved.
Hrishi
You may have accidentally enabled QoS on the PC.
Sent from my ONE E1003 using Tapatalk
Open Group Policy Editor by pressing win+r ( keys ) and opening the run box. type the following :
gpedit.msc
Hit Enter ( key )
Go To = Local Computer Policy > Administrative Templates > Network > QOS Packet Scheduler , then on the right window, right click on the Limit reservable bandwidth setting and select the Edit:
On the setting tab, select the enabled radio button, and Where it says “Bandwidth limit %“, change it to 0 or as per your liking.
Now, go to Control Panel > Network and Internet > Network and Sharing Center and Click on Change adpater settings
Right-click on your desired connection interface connection and select Properties :
Make sure QOS Packet Scheduler is selected.
