J
joy.das.jd
Guest
I have a P4 processor (Intel P4 515) on my HP pavilion a815i. There are 2 hard disks, 3 RAMs (256+256+512) and a DVD writer (SONY DRU-190A). My problem is that recently my CPU has started to run very hot. Sometimes the temperature reaches even 88 C. Even the idle temperature is around 65C.I am using a coolermaster heatsink for the cpu. I cannot make out the model number and the SMPS make is BESTEC (250W). It says 14A on the 12 V rail.
Earlier the temperature would reach a max of 60. But now it hovers around 75. I opened my cabinet and cleaned all the dust and grime of my computer but still no effect. Now my question is this due to the thermal paste drying up or a faulty SMPS ,as Speedfan gives the following results on the voltages :
+5V : 4.95 V
Vcpu : 2.16 V
Vcc : 3.28 V
+5V : 4.95 V
+12V : 11.80 V
+3V : 3.38 V
Vbat : 0.00 V
Please help me find the reason for cpu running so hot. Also what should i do get the fan run silently as before. By the way one more question. Can i attach another hard drive on my PC?
+5V : 4.95 V
Vcpu : 2.16 V
Vcc : 3.28 V
+5V : 4.95 V
+12V : 11.80 V
+3V : 3.38 V
Vbat : 0.00 V
