Alive_Hunter
I have many movies on DVD ..which i want to convert to AVI files.
which software should i use..
which can give me give me small size avi like 450 to 600MB.
also the quality should be good enough to view in full screen
what should be the setting..
i.e. resolution, video codec, audio codec, audio kbps, sampling rate..
can any body provide me with these settings...
Thanks.
Thanks.
