1. Hi Guest
    We are running a survey about laptop service in India, and we'd love your inputs. Please help us improve the quality of laptop servicing, and if you've had any bad experiences, now is the time to be heard.
    Take the survey
Bootup problem!!!!! plz HELP!!!
Discussion in 'Software Q&A' started by KKK, Feb 6, 2006.
Thread Status:
  1. KKK
    KKK New Member
    Jun 11, 2005
    26
    0
    0
    Kharagpur
    i assembled a new system with the following
    athlon 64 3200+
    ASUS A8N-E mobo
    XFX GeForce 6600GT 256MB PCIe
    2x160GB Seagate Barracuda 7200.9 SATA 1 HDDs
    2x512MB Transcend Jet RAM modules (2.5,3,3)
    VIP 400W PSU
    my problem is that the even after checking and rechecking the connections....the PC does not boot up...it starts but there is no startup beep!!!
    also if i try to switch it off by pressing the Power Button for four seconds...only the Power LED goes off and the rest of the system is on...and thats where i loose control of the system because the only way then to switch off the system is to cut off mains power!!
    PLZ HELP!!!! :(
  2. senthilrek
    senthilrek New Member
    Oct 23, 2004
    62
    0
    0
    Chennai
    I think there should some problem with the Boards Front Panel. If its a new one ask your your vendor to show you the display. Thats the simple way i think.
  3. hermit
    hermit New Member
    Dec 28, 2005
    151
    2
    0
    Plz check the smps connection s once again
  4. ::cyborg::
    ::cyborg:: Member
    Oct 5, 2005
    438
    8
    18
    NEW DELHI
    yes i think u by mistake inserted the wong led wire in the jumper recheck the jumper and also consult ur manual it is only the think which can help u out
    and were u wearing the anti static wrist wrap while assembling??????????
Thread Status:
Share This Page
