Boot Problem(fan problem)
madmoody
Hey Friendzz...,,,
problem out here ???need solution!!!!
My PC just refuses to boot everytime nowadays.When i press the "On" Button the PC Fan Starts spinning,but ,after some time it stops and the rumbling of the CPU stops.
Although the green LED Still Glows on my CPU..kindly advice bcoz..after ths i hav to manually turn off the PC and i guess its not good for its health
neways all the guyz out herre R ROCKING!!!!!!!!
Kiran.dks
I guess the problem is with the SMPS. Try shorting Green & black wire. If the fans run, then SMPS is working well, else replace with new one.
47shailesh
Security Exp
I agree that prob is with SMPS...not with the RAM , coz if it would ba RAM prob then even FAN would not spinned.....dust ur SMPS check for burnout cables in it ensure proper voltage for the SMPS..
