24PIN EPS/ATX Power Extension Cable - wanted urgently
jd21
i want one 24-pin power extension cable for my PSU/SMPS like the one below,
NEW 24PIN EPS/ATX Power Extension Cable 16" lot of 5 - eBay (item 360322669484 end time Feb-23-11 01:48:39 PST)
coz, my psu 24-pin power cable is little bit short to connect with the motherboard. plz, suggest me where i can get.
coderunknown
Retired Forum Mod
24pin? usually its the 4/8 pin short. anyway go for it. BTW what PSU are you using? cause if you using a generic one, a new psu will cost less.
