Front panel audio port is not working
Discussion in 'Hardware Q&A' started by fz8975, Aug 29, 2011.
  1. fz8975
    fz8975 .
    Jun 19, 2011
    615
    4
    18
    My front panel audio port is not working
    USB ports are working fine ...
    help !!!!
  2. d6bmg
    d6bmg BMG ftw!!
    Aug 6, 2011
    6,722
    8
    0
    Kolkata, India
    Check the audio panel connectors to the motherboard and see whether any port is loosely connected or disconnected or not.
  3. OP
    fz8975
    fz8975 .
    Jun 19, 2011
    615
    4
    18
    i've checked that its not working ..
    any other suggestion ??
  4. pimpom
    pimpom New Member
    Jul 13, 2004
    1,357
    2
    0
    Check if front audio is enabled in software audio controls.
  5. johnybravojr
    johnybravojr New Member
    Jan 12, 2009
    86
    0
    0
    What motherboard is it? I had the same problem before with an Asus MoBo(don't remember the model). I cracked my brain literally to get it working. Then it was the vendor's turn. We tried audio drivers, different ports, different headphones, it just wouldn't work. The vendor was a tech enthusiast, so he took it as a challenge to get it working. They usually dismiss such complaints by asking the user to use the back panel instead.
    Finally he sent the MoBo to R***i Perepherals and got me a slightly upgraded MoBo and then it worked. Its an Asus P5QL Pro if I remember correctly. I spent hours to get it work. I strongly recommend you to ask them to check the Motherboard, or you will waste time and energy in vain.
    I was told by the vendor that most MoBo manufacturers doesn't give a damn about the front panel, and most often the customer ends up using the back panel.
  6. OP
    fz8975
    fz8975 .
    Jun 19, 2011
    615
    4
    18
    front panel audio is enable in the software which controls audio (realtek)
    mobo - asus p5gz mx
    it was working fir more than a year
    but now it doesn't
    may be i have to get 'used to' with the back panel ...
  7. asingh
    asingh New Member
    May 28, 2008
    5,317
    16
    0
    New Delhi
    Not really. Just re-do the internal wiring once.
  8. d6bmg
    d6bmg BMG ftw!!
    Aug 6, 2011
    6,722
    8
    0
    Kolkata, India
    Why are you censoring rashi's name? :unsure:
  9. OP
    fz8975
    fz8975 .
    Jun 19, 2011
    615
    4
    18
    will try that tomorrow :-|
  10. mithun_mrg
    mithun_mrg Active Member
    Oct 1, 2003
    1,338
    11
    38
    Assam
    @op firstly what chassis u have i have i have seen 70% of those cheap cases FP dosen't work consistently try for getting a replacement FP module from the dealer if avilable
  11. johnybravojr
    Jan 12, 2009
    86
    0
    0
    Lol. I wasn't sure if I could mention names here! :blink::noob:
  12. anshul_sood
    anshul_sood New Member
    Nov 22, 2004
    49
    0
    0
    Game world
    Try to update your audio driver. I too had the same problem in my pc last time I formatted
  13. d6bmg
    d6bmg BMG ftw!!
    Aug 6, 2011
    6,722
    8
    0
    Kolkata, India
    Buddy, this is an open forum. You can mention any mane related to respective discussion without any hesitation.
    Back on your problem, you may even try to update your audio drivers. Just my 2 cents. :)
  14. BL1S
    BL1S New Member
    Apr 17, 2012
    1
    0
    0
    ASUS motherboard doesnt support HD AUDIO it has only 1 SLOT for Normal audio ... welll Go to BIOS > ADVANCED > FRONT PANNEL SETTING > SET IT AC97 to HD AUDIO may be this will help in this :/
    sorry for Bad ENGLISH !
Share This Page
