Buying Advice for LED 43 inch TV
bhasko28
Hello Guys,
I want to buy an LED TV 43 inch ofcourse HD and i need the best ones that is there at around rs.35000 to 45000. I have very less knowledge when it comes to selecting a TV. So i need your expert advice on how to select the best tv under my budget. My prefered brands are Samsung,LG,Panasonic also please suggest me if there is any other options. I will not buy Micromax or Panorama or Intex.
thanks in advance,
Warm Regards,
Bhasker
Hello Guys,
thanks in advance,
Warm Regards,
Bhasker
LG 108cm (43) Full HD Smart LED TV Online at best Prices In India
OR
Philips 109cm (43) Ultra HD (4K) Smart LED TV Online at best Prices In India
Not many options from big brands in this price range for a 43" HD LED TV.I suggest you to visit local showrooms & check models from brands like sony,lg,samsung,philips,panasonic in your budget.Also whichever model you buy,definitely get extended warranty for 1-2 years besides the usual 1 year standard warranty because now-a-days LED TVs usually give problems after 1 year by which time standard warranty is over.
